Wall Switch - with and without neutral wire
As I can see in the documentation you have differences between Wall Switches:
- most obvious is "neutral wire" - one has it another don't
- second is "ZigBee repeater function" - the one with neutral wire has that additional function so we can build a "mesh web"
but why there is a difference between power input?
- Power Input: 10A MAX,250V AC - for the version with a neutral wire
- Input voltage: 220V AC,50Hz - for the version without a neutral wire
250V and 220V?
In EU we have almost everywhere 230V 50Hz and I have tested the version without neutral wire - it works fine. Does it mean that version with a neutral wire won't?
250V and 220V?
You can use these two versions of the Wall Switch. but they are Chinese version and not certified in EU.
